SST89C58电子盘电路及代码
发布时间:2011-6-22 11:51
发布者:circuit_share
Reference design for SST ATA-Disk Chip into 8051 microcontroller Application note Abstract: this application note introduces the hardware and firmware of reference design for SST ATA-Disk Chip SST58SD/LDxxx into SST FlashFlex51 SST89C54/58 (8051 compatible microcontroller). 1.Hardware connections: Please reference to attached schematic diagram for hardware connections. SST ATA-Disk Chip (ADC) SST58SD/LDxxx only supports one working mode, ie. ATA/IDE mode, all control signals are connected based on Table 2-8, Page 14 on datasheet. After executed Set Feature Command to enable 8-bit data transfers, all higher 8 bit data bus ( D8-D15) are don’t care and can be No Connect. RESET# (pin1) is optional, it can be tied up to Vcc if not used. After power-up, ADC will automatically be reset internally, it doesn’t need external reset input. But it’s a good practice to connect RESET# to one of I/O pins such as P1.4, in case ADC is out of control for any unknown reasons, host MCU has capability to reset ADC. DASP# is connected to an emitting diode through a resistor to Vcc, LED provides user a visibility of ADC’s internal operation. When ADC is active busy on operation, LED will be on. Please be noted that master/slave selection at CSEL pin won’t take effect until Next reset, in other words, if you change the jumper setting of master/slave selection, you MUST reset ADC once. Ifyour application system expands any other I/O or data memory, please modify the reference design: (1)change CS3FX# to Vcc, (2)connect the output of address decoder to CS1FX#.When both CS1FX#and CS3FX# are high,ADC is de-selected and be standby state, all data bus are in high-z. When CS1FX# is low, ADC is selected and be operational. So CS1FX# acts as Chip Select (/CS) in most common peripherals. 2.Firmware design guide: It’s important to know that ATA/IDE standard doesn’t permit access only one byte at a time to its media such as HDD or ADC, firmware must read or write data sector by sector, 1 sector has 512 bytes of data,system design engineer must design data buffer to support random access to ADC. Reference design uses the secondary block (4Kbytes x 8bit) of on-chip flash in SST89C54/58 as data buffer. After power-up or external reset, ADC is default to be 16-bit operation. As SST89C54/58 is 8-bit MCU, firmware must enable 8-bit operation by Set Features Command, please reference to page 32 on datasheet. If ADC is set as Slave, other than Master, you need to change the bit4 in Drive/Head Register to be 1 when writing Command to ADC, see page 17 on datasheet. After power-on or reset,ADC will be ready to read / write operation after 200ms (typical), 500ms (maximum), see page 1 under Start Up Time in Features on datasheet. 3.Conclusion: It’s easy to modify this reference design to any other embedded controllers as long as you follow above design guidelines. 4.Schematic diagram: 5.8051 Source code: ; all commands supported by ADC. ChkPwrEqu0E5h; 98h DiagnosticEqu90h FormatEqu50h IdentifyEqu0ECh IdleEqu0E3h; 97h IdleImmEqu0E1h; 95h InitializeEqu91h ReadBufEqu0E4h ReadLongEqu22h; 23h ReadMultiEqu0C4h ReadSctrEqu20h; 21h ReadVerifyEqu40h; 41h RecalibrateEqu10h; 1xh SeekEqu70h; 7xh SetFeatureEqu0EFh SetMultiEqu0C6h SleepEqu0E6h; 99h StandbyEqu0E2h; 96h StandbyImmEqu0E0h; 94h WriteBufEqu0E8h WriteLongEqu32h; 33h WriteMultiEqu0C5h WriteSctrEqu30h; 31h WriteVerifyEqu3Ch ;============================================================= ; ADC Drive Register Set definitions Data_RegEqu8000h; Data Register for read / write Error_RegEqu8001h; Error Register, read only FeaturesEqu8001h; features Register, write only Sectr_CntEqu8002h; Sector Count Register ( R / W ) Sectr_NoEqu8003h; Sector Number Register, or LBA0:7 ( R / W ) Cylinder_LowEqu8004h; Cylinder Low Register or LBA8:15 ( R / W ) Cylinder_HiEqu8005h; Cylinder High Register or LBA16:23 ( R / W ) Drv_HeadEqu8006h; Drive Head Register ( R / W ) StatusEqu8007h; Status Register, read only CommandEqu8007h; Command Register, write only Alt_StatusEqu4006h; Alternate Status Register, read only, ; reading Alt_Status doesn't clear interrupt pending flag. Not used in this demo. Device_CtrlEqu4006h; Device Control Register, write only. Not used in this demo. Drive_AddrsEqu4007h; Drive Address Register, read only. Not used in this demo. ;================================================================= ; SST FlashFlex51 microcontroller related SFR's definition SFCFDATA0B1H; SuperFlash Configuration SFCMDATA0B2H; SuperFlash Command SFALDATA0B3H; SuperFlash Address Low SFAHDATA0B4H; SuperFlash Address High SFDTDATA0B5H; SuperFlash Data SFSTDATA0B6H; SuperFlash Status WDTCDATA0C0H; Watchdog Timer Control WDTDDATA86H; Watchdog Timer Data/Reload ;================================================================= ; constantdefinition FlashAddrsEqu0F800h; start address to store data from ADC ;=========================================== org0000h ljmpstart org0100h start:clrP1.4; reset ADC nop nop nop nop setbP1.4 movr4, #5; delay 0.5 second loadr5:movr5, #200; delay 0.1 second loadr6:movr6, #250; delay 0.5ms for 12MHz crystal djnzr6, $ djnzr5, loadr6 djnzr4, loadr5 acallEnable8bit; First of all, enable 8 bits operation! ;======================================== orlSFCF,#40h; IAPEN=1 movSFAH,#high(FlashAddrs) movSFAL,#low(FlashAddrs) movB,#8; erase 8 sectors (512 bytes) ;======================================== erase:movSFCM,#0Bh; sector erase! acallDone? mova,SFAL adda,#64;64 bytes / sector in Block 1 of SST89C54/58 movSFAL, a mova,SFAH addca,#0 movSFAH, a djnzB,erase anlSFCF,#0BFh; disable IAP ;======================================== main:acall Write_Sctr acall Read_Sctr acall Compare jbF0, fail clrP1.4; indicates successful operations. setbP1.5 sjmp$ fail:clrP1.5; flags failed comaprison. setbP1.4 sjmp$ ;======================================== Function:acallBusy movdptr, #Sectr_Cnt mova, R2; R2 is Sector Count movx @dptr, a movdptr, #Sectr_No mova, R3; R3 contains LBA0:7 movx @dptr, a movdptr, #Cylinder_Low mova, R4; R4 contains LBA8:15 movx @dptr, a movdptr, #Cylinder_Hi mova, R5; R5 contains LBA16:23 movx @dptr, a movdptr, #Drv_Head mova, R6; R6 contains LBA24:27 anla,#00001111b orla,#11100000b; bit4=0 as MASTER-p.htm" target="_blank" title="MASTER货源和PDF资料">MASTER, 1 as Slave; bit6=1, enable LBA. movx @dptr, a movdptr, #command mova, R7; R7 is command code. movx @dptr, a ret ;======================================== Busy:movdptr, #status movx a, @dptr jbacc.7, Busy jbacc.0, errors ;jnbacc.6, Busy clra; acc=0 when successful clrC; C=0, ADC is not busy (BUSY=0) and no error (ERR=0) ret; and is ready to accept commands (RDY=1) errors:movdptr, #Error_Reg movx a, @dptr setb C; C=1 flags error codes contained in ACC register ret ;======================================== WaitDRQ:movdptr, #status movx a, @dptr jbacc.7,WaitDRQ; if BUSY=1, then WaitDRQ jnbacc.3, WaitDRQ; if DRQ=0, then WaitDRQ jbacc.0,errors; if ERR=1, then read errors code and set flag C ;jnbacc.6, WaitDRQ clra clrC; C=0, ADC is BUSY=0, DRQ=1, ERR=0. ret ;======================================== Done?:mova, SFST jbacc.2,Done? ret ;======================================== Enable8bit:acall Busy movdptr, #Features mova,#01h; enable 8 bit data transfer movx@dptr, a movdptr, #Drv_Head mova,#11100000b; bit4=0 as MASTER-p.htm" target="_blank" title="MASTER货源和PDF资料">MASTER, 1 as Slave ; bit6=1, enable LBA movx@dptr, a movdptr, #COMMAND mova,#SetFeature; #0EFh movx@dptr, a ret ;======================================== Write_Sctr:movR2,#1; write 1 sector at a time. movR3,#0Ah; suppose LBA to be 000000Ah movR4,#0 movR5,#0 movR6,#0 movR7,#WriteSctr acallFunction acallWaitDRQ acallWrite512 ret ;======================================== Write512:movR0,#high(message) ; get the higher address of message movR1,#low(message); get the lower address of message movR7,#2; 512 bytes = 2 * 256 movB,#0 write:movdph,R0; get the address movdpl,R1 clra movca,@a dptr; get the data in message incdptr; point to next byte in message movR0,dph; save the address movR1,dpl movDPTR, #Data_Reg; point to ADC movx@dptr, a; write 1 byte data into ADC djnzB,write djnzR7, write; write all 512 bytes to ADC ret ;======================================== Read_Sctr:movR2,#1; read 1 sector at a time. movR3,#0Ah; suppose LBA to be 000000Ah movR4,#0 movR5,#0 movR6,#0 movR7,#ReadSctr acallFunction acallWaitDRQ acallRead512 ret ;======================================== ; read 1 sector of 512 bytes data and write into flash on chip of SST FlashFlex51 MCU Read512:movR7,#2; 512 bytes = 2 * 256 movB,#0 movdptr,#Data_Reg movSFAH, #high(FlashAddrs) movSFAL, #low(FlashAddrs) orlSFCF, #40h; set IAPEN=1 to enable IAP read:movxa,@dptr; read 1 byte data from ADC movSFDT, a; program into on-chip flash movSFCM, #0Eh; issue Byte-Program command acallDone?; wait until done mova,SFAL; adjust the address of flash adda,#1 movSFAL, a mova,SFAH addca,#0 movSFAH, a djnzB,read djnzR7, read anlSFCF, #0BFh; disable IAP ret ;======================================== Compare:movdptr,#message;point to message movSFAH,#high(FlashAddrs) movSFAL,#low(FlashAddrs) orlSFCF, #40h; IAPEN=1 clrF0 movR7,#2 movB,#0 verify:clra movca,@a dptr; getoriginal data in message incdptr movSFCM, #0Ch; issue BYTE-VERIFY command nop xrla, SFDT; SFDT contains datain flash, these data come from ADC jzskip setbF0; set flag F0 (PSW.5) if any discrepancy. skip:mova,SFAL; increase the address of flash adda,#1 movSFAL, a mova,SFAH addca,#0 movSFAH, a djnzB,verify djnzR7, verify anlSFCF, #0BFh; disable IAP ret ;======================================================================== messageB"This demo program demonstrates how easy to design " DB"SST ATA-Disk Chip into SST FlashFlex51 embedded microcontroller. " DB"After you understand how to use the basic WriteSector and ReadSector " DB"functions, it's easy to try any others." DB"The hardware connection between ADC and MCU is also very simple," DB"just like you expand any I/O or data memory in your application system. " DB"After power-on, ADC is default to be 16 bit operation as all EIDE " DB"standards, firmware needs enable 8 bit operation before " DB"further write / read operation." end |
