ADI AD9122高速DAC和ADL5373 I-Q调制器接口解决方案
发布时间:2011-8-29 12:10    发布者:Liming
关键词: AD9122高速DAC , ADI , ADL5373 , I-Q调制器 , 接口
ADI公司的AD9122是双路高动态范围的高速DAC,取样速率1230MSPS,灵活的LVDS接口, 122.88 MHz IF的单载波WCDMA ACLR为82dBc, RL = 25 Ω to 50 Ω时的模拟输出从8.7 mA 到31.7 mA可调,集成了2x/4x/8x内插/复数调制器,使得载波可放置在DAC带宽内任何地方, 1.2 GSPS的功率为1.5W, 500 MSPS的功耗为800mW,主要用在无线基础设备, W-CDMA, CDMA2000, TD-SCDMA, WiMAX, GSM, LTE和宽带通信如LMDS/MMDS,点对点通信,数字高或低IF合成.本文介绍了AD9122主要特性, 功能方框图, AD9122评估板以及AD9122高速DAC和ADL5373 I-Q调制器接口解决方案,包括接口电路, AD9122-M5375-EBZ评估板电路图和材料清单.
Interfacing the ADL5375 I/Q Modulator to the AD9122 Dual Channel, 1.2 GSPS High Speed DAC
The AD9122 is a dual, 16-bit, high dynamic range digital-to- analog converter (DAC) that provides a sample rate of 1230 MSPS, permitting multicarrier generation up to the Nyquist frequency.
The AD9122 TxDAC+® includes features optimized for direct conversion transmit applications, including complex digital mod- ulation, and gain and offset compensation. The DAC outputs are optimized to interface seamlessly with analog quadrature modulators, such as the ADL537x F-MOD series from Analog Devices, Inc. A 4-wire serial port interface provides for program- ming/readback of many internal parameters. Full-scale output current can be programmed over a range of 8.7 mA to 31.7 mA. The AD9122 comes in a 72-lead LFCSP.
PRODUCT HIGHLIGHTS
1. Ultralow noise and intermodulation distortion (IMD) enable high quality synthesis of wideband signals from baseband to high intermediate frequencies (IF).
2. Proprietary DAC output switching technique enhances dynamic performance.
3. Current outputs are easily configured for various single- ended or differential circuit topologies.
4. Flexible LVDS digital interface allows the standard 32-wire bus to be reduced to one-half or one-quarter of the width.
AD9122主要特性:
Flexible LVDS interface allows word, byte, or nibble load
Single-carrier W-CDMA ACLR = 82 dBc at 122.88 MHz IF
Analog output: adjustable 8.7 mA to 31.7 mA, RL = 25 Ω to 50 Ω
Integrated 2×/4×/8× interpolator/complex modulator allows carrier placement anywhere in the DAC bandwidth
Gain, dc offset, and phase adjustment for sideband suppression
Multiple chip synchronization interfaces
High performance, low noise PLL clock multiplier
Digital inverse sinc filter
Low power: 1.5 W at 1.2 GSPS, 800 mW at 500 MSPS, full operating conditions
72-lead, exposed paddle LFCSP
AD9122应用:
Wireless infrastructure
Digital high or low IF synthesis
Transmit diversity
Wideband communications: LMDS/MMDS, point-to-point
图1.AD9122功能方框图
图2.AD9122典型的信号链框图
AD9122评估板
The AD9122 Evaluation Board connects to the Analog Devices Digital Pattern Generator (DPG2) to allow for quick evaluation of the AD9122. The DPG2 allows the user to create many types of digital vectors and transmit these at speed to the AD9122 in any of the AD9122 operating modes. The AD9122 evaluation board is configured over USB with accompanying PC software.
图3. DPG2和AD9122评估板外形图
图4.AD9122评估板和DPG2连接图
This circuit provides a simple and flexible interface between the AD9122 dual high speed TxDAC digital-to-analog converter and the ADL5375-05 broadband I/Q modulator.Because the DAC outputs and ADL5375-05 I/Q modulator inputs share a common bias level of 0.5 V, there is no need for any active or passive level shifting circuitry. The dc coupled interface facilitates I/Q modulator local oscillator (LO) leakage compensation by the DAC.
The 1.2 GSPS AD9122 DAC sampling rate and the wide bandwidth of the ADL5375-05 modulator I and Q inputs ensure that both zero-IF (ZIF) or complex-IF (CIF) architectures can be supported. In addition to filtering Nyquist images, the baseband filter provides excellent rejection of both differential-mode and common-mode DAC spurs.
图5.AD9122和ADL5375-50接口电路: 50 Ω电阻接地, 500 mV DC偏压用于ADL5375-50带通滤波器输入
图6.AD9122和ADL5375-50接口电路:10MHz三阶Bessel滤波器
图7.推荐的AD9122和ADL5375-50接口电路:Fc=300MHz五阶Butterworth滤波器
图8.AD9122-M5375-EBZ评估板外形图
图9.AD9122-M5375-EBZ功能测试连接图
图10. AD9122-M5375-EBZ电路图(1)
图11. AD9122-M5375-EBZ电路图(2)
图12. AD9122-M5375-EBZ电路图(3)
图13. AD9122-M5375-EBZ电路图(4)
图14. AD9122-M5375-EBZ电路图(5)
图15. AD9122-M5375-EBZ电路图(6)
AD9122-M5375-EBZ材料清单见:
xls.gif AD9122-M5375-EBZ材料清单.rar (7.62 KB)
http://www.analog.com/static/imported-files/data_sheets/AD9122.pdf
http://www.analog.com/static/imported-files/circuit_notes/CN0205.pdf
本文地址:https://www.eechina.com/thread-74681-1-1.html     【打印本页】
1770309616 发表于 2011-9-27 23:46:50
详情请见:
AD9122[2].pdf
1.21 MB, 下载积分: 积分 -1
