Maxon explosion-proof industrial wireless access point, bridge, router, DTU
发布时间:2023-2-16 10:24
发布者:wifi6_module
Maxon explosion-proof devices for industrial hazardous areas. Access point, long-distance wireless bridge, router, DTU, etc. Safety is always our primary concern. WiFi5 AP MX811-1F: Ex d IIB T6 Gb/ExtD A21 IP68 T80℃ MX911-1F: Ex d IIC T6 Gb/ExtD A21 IP68 T80℃ 802.11a/b/g/n/ac, 1x 1G WAN port, 1x 1G LAN port or SFP optical port, PoE power supply, 2 external antenna connectors, Max. throughput 1167Mbps, wide operation range -40~80℃, Support MAXON positioning software WiFi6 AP MX821-1F: Ex d IIB T6 Gb/ExtD A21 IP68 T80℃ MX921-1F: Ex d IIC T6 Gb/ExtD A21 IP68 T80℃ 802.11a/b/g/n/ac/ax, 1x 2.5G WAN port, 1x 2.5G LAN port or 2.5G SFP optical port, PoE power supply, 2 external antenna connectors, Max. throughput 1766Mbps, wide operation range -40~80℃, Support MAXON positioning software WiFi6 Pro AP MX821-1F V2: Ex d IIB T6 Gb/ExtD A21 IP68 T80℃ MX921-1F V2: Ex d IIC T6 Gb/ExtD A21 IP68 T80℃ 802.11a/b/g/n/ac/ax, 1x 2.5G WAN port, 1x 2.5G LAN port or 2.5G SFP optical port, PoE power supply, 6 external antenna connectors, Max. throughput 65730Mbps, wide operation range -40~80℃, Support MAXON positioning software WiFi5 Bridge MX834-1D: Ex d IIB T6 Gb/ExtD A21 IP68 T80℃ MX934-1D: Ex d IIC T6 Gb/ExtD A21 IP68 T80℃ 802.11ac, PoE power supply, support Access point, client, WDS access point,WDS client, support dual hardware backup, support remote control and management WiFi6 Bridge MX821-2P: Ex d IIB T6 Gb/ExtD A21 IP68 T80℃ MX921-2P: Ex d IIC T6 Gb/ExtD A21 IP68 T80℃ 802.11ax, 4*4, 4800Mbps, 1x 2.5G WAN port, PoE power supply, 5km transmission 4G Router MX834-1D: Ex d IIB T6 Gb/ExtD A21 IP68 T80℃ MX934-1D: Ex d IIC T6 Gb/ExtD A21 IP68 T80℃ 1x 10/100/1000M adaptive WAN port, 1x 10/100/1000M adaptive LAN port, online remote control platform, support remote upgrade & configuration, support 2.4G 5.8G wireless client & wireless AP function, support TCP, UDP transparent transmission mode, TCP Server mode 5G Router MX844-1D: Ex d IIB T6 Gb/ExtD A21 IP68 T80℃ MX944-1D: Ex d IIC T6 Gb/ExtD A21 IP68 T80℃ 1x 10/100/1000M WAN port, 3x 10/100/1000M LAN port, support PoE power supply, support stable 5G/4G/3G Cellular, dual-band WIFI, WiFi supports AP & client mode 4G DTU MX832-1D: Ex d IIB T6 Gb/ExtD A21 IP68 T80℃ MX932-1D: Ex d IIC T6 Gb/ExtD A21 IP68 T80℃ 1x RS232, 1x RS485, preserved 3x I/O with 2x ADC, Support transparent transmission mode, embedded with standard TCP/IP protocol stack, support multi-center and TCP server functions, ultra-low power consumption design, including sleep mode, set-time online offline mode 5G DTU MX842-1D: Ex d IIB T6 Gb/ExtD A21 IP68 T80℃ MX942-1D: Ex d IIC T6 Gb/ExtD A21 IP68 T80℃ 1x 10/100/1000 electical port, 1x RS-232/485, support 5G SA/NSA networking, Backward compatible with 4G/3G network standard AC Controllor MX-AC94A0-06: non-explosion-proof 1x Console, 6x 1G port, 2x USD2.0, Max. 1024pcs AP control, Max. username 8000 Positioning Software MX-SLSYSV1.1: Software Real-time location monitoring, historical track playback, map & tag management, precise personnel location visualization by wireless AP, tags and algorithms |
